Warning message
Cisco 2620 -> 3Com 4400 route on stack VLAN 1 Problem
interface FastEthernet0/0
no ip address
speed 100
half-duplex
no cdp enable
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0.3
encapsulation dot1Q 3
ip address 192.168.3.1 255.255.255.0
Here are the 2620 config. and connect to 3Com 4400.
VLAN 2, 3 PC can ping VLAN 2,3 default gateway. but VLAN 1 can't ping
We found that if add one more sub-interface VLAN4
interface FastEthernet0/0.4
encapsulation dot1Q 4 native
then the VLAN 1 PC can ping VLAN 1 default gateway.
anyone can tell me what's happening ?
smahbub Mon, 07/01/2002 - 13:18
  • Silver, 250 points or more
Sounds like a native VLAN mismatch, check to see what your native VLAN is set to on both sides of the connection. Also, make sure the device pinging VLAN 1 gateway is actually on VLAN 1.
