Warning message
Dialer DTR disconnects very quick
Jun 25th, 2002
  • Bronze, 100 points or more
I have configured an interface with the following configuration:
interface Serial4<br>
ip address 172.16.253.1 255.255.255.252<br>
no ip directed-broadcast<br>
keepalive 60<br>
dialer dtr<br>
dialer idle-timeout 300<br>
dialer wait-for-carrier-time 60<br>
dialer-group 1<br>
no cdp enable<br>
end<br>
dialer-list 1 protocol ip list 101<br><br>
The DDR seems to do what it should do, it dials when needed, but the modem hangs up while still dialing the number, or in or imediately after negotiation. Sometimes it passes this, and remains connected and works as needed. The problem is that the success rate is very low (about 1 of 10 tries). There are no line problems. Also, the modem seems fine (if i remove dialer dtr and the router keeps DTR up all time, the modems connect to each other and remain connected since the first try). The interface on the other router has only the ip address configured.
Anonymous (not verified) Tue, 06/25/2002 - 09:39
You can either try "debug serial inter"
to see what the physical signals are doing,
or get a break out box. The only control
the router has over the modem is via DTR;
if we are lowering DTR while the modem is
dialing, then the problem is at the cisco.
If DTR stays up while carrier drops, then
the problem is either the modem or the remote
end (in which case you would try the same
test at the remote end).
