Warning message
2501 does not keep configuration
Jun 25th, 2002
  • Bronze, 100 points or more
2501, IOS 12.0, config, save and show run: configuration is correct.
Shutdown and restart 2501:
It kept go to the intial config,
all the configuration before was lost.
Anonymous (not verified) Tue, 06/25/2002 - 09:39
It is possible that the Configuration register value is set to Ignore NVRAM. Reset this and check
