Anonymous (not verified) Tue, 06/25/2002 - 09:39
variance
To control load balancing in an IP enhanced IGRP-based internetwork, use the variance router configuration command. To reset the variance to the default value, use the no form of this command.
variance multiplier
no variance
Syntax Description
multiplier Metric value used for load balancing. It can be a value from 1 to 128. The default is 1, which means equal-cost load balancing.
Default
1 (equal-cost load balancing)
Command Mode
Router configuration
Usage Guidelines
Setting a variance value lets the router determine the feasibility of a potential route. A route is feasible if the next router in the path is closer to the destination than the current router and if the metric for the entire path is within the variance. Only paths that are feasible can be used for load balancing and included in the routing table.
If the following two conditions are met, the route is deemed feasible and can be added to the routing table:
The local best metric must be greater than the metric learned from the next router.
The multiplier times the local best metric for the destination must be greater than or equal to the metric through the next router.
Example
The following example sets a variance value of 4:
router eigrp 109
variance 4
