Warning message
What is counted as a failed call (ISDN), when you use the command "sh dialer"?
Jun 25th, 2002
  • Bronze, 100 points or more
What is a failed call and then marked as a failed call in the command "sh dialer" in a Cisco 800?
Is there a document describing this?
String Successes Failures Last DNIS Last status
00855630100 2 0 00:00:09 successful Default
Anonymous (not verified) Tue, 06/25/2002 - 09:39
The columns are self explanatory.
failed calls means calls that we do not receive a connect
for as in, phone might ring and not picked up, call my be disconnected due to
other reason etc.
successful call are call that we actually pick up and a connect was received in a q931. even
if it disconnects after few seconds it still counted
as successful.
last DNIS, is the last called number dialed through the dialer
interface.
