Catalyst 4003 : both layer 3-module(4232rj45) AND GBIC 18port-module in same chassis possible ?
admin_2
Level 3
Level 3
Is it possible to install layer3-module
AND 18port GBit GBIC-module in the same chassis of catalyst 4003 ???
Does the layer 3 module have appletalk routing capabilities ???
Not applicable
yes, you can have both in the same chassis.
The l3 module has the appletalk routing capability if you run 12.0(10)W5(18f) ioS On the layer3 module.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/78_10853.htm
