Warning message
Import all Phone, CTI ports, CTI route points and route patterns
Jun 26th, 2002
I have a broken SQL database. I have a TAC case open for this, but it is taking time to solve. I am currently rebuilding the CallManager on another CM.
Under the route plan>route plan report, I have selected view in a file.
This list is in a .CSV fomat. Is there a way of importing this list into my new CM?
I have tried BAT, but the field format is different and the with BAT I can only import the Phones and CTI ports.
What about all the route patterns, Call pickup, conference and translation patterns?
Or can I extract this info from the SQL DB?
Please help
Marius
gary.shaw Wed, 06/26/2002 - 06:05
Being able to import a dial plan of route patterns from .csv etc would be very nice, but I dont think such an option exists Im afraid.
mimckee Wed, 06/26/2002 - 06:56
  • Cisco Employee,
I am not sure of any way to do this at the current time. The only thing BAT gets you is phones, users, and some gateways. I don't know of anything thing that does route patterns. Here is are the release notes for all the things BAT supports.
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/admin/bulk_adm/relnote/bat421rn.htm
I did not think the route plan report gave you phones and cti ports. If you have a backup and name the new machine the same name as the old one then you can restore a backup on the new machine.
Thank you,
-Mckee
m.taljaard Thu, 06/27/2002 - 21:53
Tanks for the reply.
I have backups, but they all have the database problem. No backup is available without the database problem.
I have now done import of all the phone informaion into BAT and exported it to .csv files, but when I run this a file with 60 entries will only configure 20 to 30 and without indicating any error will stop. Is this a known problem?
If you view the output of the route plan>route plan report then click on view in file, you do get all the phone and CTI ports in the report. I would like to import all this information in some format.
Kind regards
Marius
m.taljaard Fri, 06/28/2002 - 01:36
Bat import works for my phones. I had a problem with the PickUPGroups number, but found that the problem was related to the PickUPGroups not being configured on the CM. I added them and ran the files again, and all worked.
Thanks for your replies.
I will enter the CTI ports via BAT and then do the gateways and Route points manually, unless you have any great idea's about doing that through some tool.
Cheers
Marius
