traceroute udp
Jun 26th, 2002
I noticed from a sniffer trace that traceroute is sending the request in UDP and the response is simply ICMP.
What would be the advantage of UDP in this case.
If I issue a traceroute fram WIN95, it is ICMP all the way.
Anonymous (not verified) Wed, 06/26/2002 - 09:33
You can define port number if you use extended trace on cisco.
if you use traceroute on unix or similar os they use udp 33434 for traceroute
windows use 33434tcp for traceroute
