Warning message
HTTP->HTTPS redirect at PIX?
Jun 26th, 2002
  • Bronze, 100 points or more
We have a solaris box behind a pix firewall. We would like to not allow port 80 traffic to the server for security reasons and only allow 443. But if users in advertently go to the http:// URL instead of the https:// - they get a page not found error which doesn't look so good. What can you recommend to help in this situation? Something in the PIX? Other?
alexis.fidalgo Wed, 07/03/2002 - 12:49
ok, suppose the lan connected to inside interface is 10.0.0/24
and the webserver at 10.0.0.2
and the ip in the outside interface is 200.0.0.1
try using
nat (inside) 1 0 0
global (outside) interface
static (inside,outside) tcp interface 80 10.0.0.2 443 netmask 255.255.255.255
static (inside,outside) tcp interface 443 10.0.0.2 443 netmask 255.255.255.255
I hope it helps
