Warning message
SNMP Monitor AS5300 through VPN Concentrator from private LAN
I'm trying to monitor a couple of AS5300's using mrtg from the private side of the network. The public interface on the VPN has the default public filter applied. My routing entries would appear to be correct as I can see the public interface on the VPN but nothing beyond that. Do I need to change something on the public filter or is there more to it than this. Any help would be appreciated.
ciscomoderator Wed, 07/03/2002 - 13:55
  • Gold, 750 points or more
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
