Warning message
two quad E1/PRI in one AS5300
Jun 27th, 2002
  • Bronze, 100 points or more
we want to use two Quad E1/PRI into one AS5300. the software is IOS Version 12.0 (7). the first one is build in slot 0 and we want to put in the second one in Slot 2. the slot 1 is occupied by Mica-Modems.
at the reboot after the build up we see the following massage on the console line.
00:00:06: Error: This system doesn't allow more than1 T1/E1/PRI card
is this a software (release), hardware (firmware) problem or is it impossible to use two interfaces in one AS
Anonymous (not verified) Thu, 06/27/2002 - 09:29
AS5300 cannot have more than 1 quad card installed on its chassis.
You might consider using an octal E1/PRI card instead.
