Warning message
Anonymous (not verified) Thu, 06/27/2002 - 14:12
ipx traceroute :)
for a detailed view use
'sh int irb' command which should give you details on which protocols are bridged or routed
if you want ipx to be bridged, disable ipx routing 'no ipx routing' - simply irb when configured bridges everything that is NOT configured as routed. Thus, if you do not enable ipx routing but enable ip routing and irb, ip will be routed while ipx will be switched
