Warning message
can the switch management vlan1 be changed on a 3500XL-EN switch?
Jun 27th, 2002
  • Bronze, 100 points or more
Is it possible to change the default switch management vlan1 on a 3524XL-EN switch?
Anonymous (not verified) Thu, 06/27/2002 - 14:12
vlan 1 is default and cannot be deleted
terry.knight Tue, 07/02/2002 - 13:53
although vlan 1 cannot be deleted, it does not need to be the management interface. for example if you wanted to change this to say 'vlan 2' the configuration would be as follows:
SWITCH#(config)interface vlan 2
SWITCH#(config-if)management
SWITCH#(config-if)ip address etc, etc
terry.knight Tue, 07/02/2002 - 13:55
