Warning message
Reset a line interface on a 26xx router
Jun 27th, 2002
  • Bronze, 100 points or more
I have a router 2611 with the Serial module 8S/A which runs the IOS vers. 12.2.7. I configure a line interface associated with it corresponding async interface. For a special reason I have to erase all command line under the line int. It's running fine with the command "default int serialx/x".
I want to do the same thing on a 2620 router with the 16 async ports module and IOS vers 12.2.7. In that situation the result of the "default int asyn x/x" is not it wanted.
Is there a command to completely reset the line interface ?
Anonymous (not verified) Thu, 06/27/2002 - 14:12
The default command does not apply to
async-interfaces (as opposed to serial
interfaces set up as async)...
