Warning message
What is the proper way to remove a backup interface dialer from a serial interface
Jun 27th, 2002
  • Bronze, 100 points or more
I use ISDN for backup purposes if one of my Frame relay sub-interfaces goes down. I am trying to remove the "backup interface dialer " command from my serial sub-interface because I want to move it to another interface on my router. Everytime I remove the line the dialer tries to dial. What is the proper way to remove it ?
Anonymous (not verified) Thu, 06/27/2002 - 14:13
You are doing it correctly. When
you remove the command, the dialer
interface goes from "standby" to
"up/up (spoofing)", which means that
if there is interesting traffic
according to your config it will dial.
If you add the backup command to the
other interface, the dialer should go
back into "standby" and all will be
well.
