Warning message
how do you upgrade a 4700 from the bootstrap?
Jun 27th, 2002
  • Bronze, 100 points or more
I tried upgrading our 4700 router, and it all seemed to be fine until I rebooted, I get the following errors when I reload:
System Bootstrap, Version 5.2(7) [rchiao 7], RELEASE SOFTWARE (fc1)
Copyright (c) 1994 by cisco Systems, Inc.
C4500 processor with 32768 Kbytes of main memory
program load complete, entrypt: 0x80008000, size: 0x37f768
Error : compressed image checksum is incorrect 0x2DE67334
Expected a checksum of 0x98EFD3B9
___ System received a Software forced crash ___
signal= #17, code= #5, context= #0
PC = 0x80008094, Cause = 0x20, Status Reg = 0x30408403
loadprog: error - on read during ELF program load
requested 3648744 (0x37ace8) bytes, got 3503143 (0x357427)
boot: cannot load "flash:"
program load complete, entrypt: 0x80008000, size: 0x248b30
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) 4500 Bootstrap Software (C4500-XBOOT), Version 10.2(7), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1995 by cisco Systems, Inc.
Compiled Thu 06-Jul-95 00:18 by rchiao
Image text-base: 0x60008780, data-base: 0x601D0000
cisco 4700 (R4K) processor (revision B) with 32768K/4096K bytes of memory.
Processor board serial number 02479837
R4700 processor, Implementation 32, Revision 2.0 (Level 2 Cache)
G.703/E1 software, Version 1.0.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
2 Serial network interfaces.
128K bytes of non-volatile configuration memory.
4096K bytes of processor board System flash (Read/Write)
4096K bytes of processor board Boot flash (Read/Write)
Press RETURN to get started!
Router(boot)>
I can't find a way to load a new image from here, or from the rommon, I've booted into the rommon and don't get an xmodem command. I'm at a loss as to how to do anything, does anyone have any ideas? Thanks
Anonymous (not verified) Thu, 06/27/2002 - 14:13
From the Router(boot)> prompt, you
should be able to go into enable mode
and "copy tftp flash" the image
again.
