Warning message
VPN tunnel through PIX
Jun 28th, 2002
Hello
I have Checpoint VPN-1 (inside) with SecuRemote (VPN Client) (outside) and
PIX between them. (two level firewall)
I opened IP/50 & 51 & udp 500, but
PIX reset connection Client to VPN-1:
pixfirewall# 302013: Built inbound TCP connection 102 for outside:213.77.20.45/1
485 (213.77.20.45/1485) to inside:192.168.30.5/264 (213.77.20.40/264)
302013: Built inbound TCP connection 103 for outside:213.77.20.45/1486 (213.77.2
0.45/1486) to inside:192.168.30.5/264 (213.77.20.40/264)
302014: Teardown TCP connection 103 for outside:213.77.20.45/1486 to inside:192.
168.30.5/264 duration 0:00:01 bytes 4641 TCP Reset-O
106015: Deny TCP (no connection) from 213.77.20.45/1486 to 213.77.20.40/264 flag
s RST on interface outside
106015: Deny TCP (no connection) from 192.168.30.5/264 to 213.77.20.45/1486 flag
s RST on interface inside
302014: Teardown TCP connection 102 for outside:213.77.20.45/1485 to inside:192.
168.30.5/264 duration 0:00:17 bytes 45 TCP FINs
Any tips ?
Pawel Florek
franzin Fri, 06/28/2002 - 09:02
As I could see (if I understand) you are using NAT to get the Checkpoint
Firewall. This is incompatible with SecureRemote if you are trying to
establish a tunnel with FWZ.
Try to use ISAKMP, make a static translation for Checkpoint and read
(if don't done) these tips:
http://www.cisco.com/warp/customer/707/cp-r.shtml
http://www.cisco.com/warp/public/707/ipsecnat.html
and perhaps this can help you:
http://www.phoneboy.com/faq/0141.html
