Warning message
Is NBAR supported on cisco1750 series routers
Jun 28th, 2002
  • Bronze, 100 points or more
I have a network with a 7204 at the centre and 1750 series at the edge. I want to implement NBAR for Citrix traffic. Does the 1750 support NBAR and if not can I just employ NBAR on the 7204 and effectively control Citrix traffic?
Anonymous (not verified) Fri, 06/28/2002 - 14:28
No, NBAR is only supported on the 7100/
7200. Lack of NBAR on the 1750 would
mean the lack of service and QOS control
on the 1750; this may/may not be a problem
for you (control would only be in 1
direction). If it is a problem, you could
look at Class Based WFQ, although it may
be tough/impossible to implement with
Citrix.
