Warning message
Why is the 11k listening on UDP ports 1024 and 5002
Jun 28th, 2002
  • Bronze, 100 points or more
After running a port scan on the 11k I've found the 11k is listening on udp ports 5002, and 1024. I'd like to know why.
Anonymous (not verified) Fri, 06/28/2002 - 14:28
5002 would/could be a raw TCP (stream)
connection to a rotary group. So
for example if you had async TTY lines in
rotary group 2, you could connect to
them via port 5002. This should be disabled
by default, and enabled with the command
"transport input telnet" under the line(s).
I don't know what port 1024 would be.
