Warning message
6509 Native IOS command to remove VLANS across a dot1q trunk?
While trying to perform the equivalent of "clear trunk" command on the 5500 series switches on a 6509 running "native IOS" and I'm running into some issues.
IOS ver: c6sup22-dsv-mz.121-11b.E.bin"
My research indicates the following command is the equivalent and should do the trick....."switchport trunk allowed vlan 1-899,902-924,926-1005"
Command intent: Remove VLANS 900, 901, and 925 from the trunk link.
6509#
interface GigabitEthernet3/9
description Connection to vbg5505-c1t P1/1
switchport
switchport mode trunk
no ip address
5505#
#module 1 : 2-port 1000BaseX Supervisor IIIG
set port trap 1/1-2 enable
set port name 1/1 VBG6509-T1T-1 P3/9
set trunk 1/1 on dot1q 1-1005
end
VBG5505-C1T> (enable) sh trunk
Port Mode Encapsulation Status Native vlan
1/1 on dot1q trunking 1
Port Vlans allowed on trunk
1/1 1-1005
Port Vlans allowed and active in management domain
1/1 1,359-361,366,370-372,380,388,900-901,925
Port Vlans in spanning tree forwarding state and not pruned
As you can see, vlans 900,901, and 925 are showing up on the 5505
bsivasub Sun, 06/30/2002 - 19:46
can you get the output of show interface gig 3/9 trunk command
thanks
