Warning message
Mgmt software for 4235
Jun 30th, 2002
Is the management software is built -in for the new IDS- 4235-K9 ?
Or, do we have to buy it separately ?
If so, what is the product number ?
CAn we use the product CWVMS-2.0-WINR-K9 in conjuction with 4235 for management ?
mhossain Mon, 07/01/2002 - 05:16
  • Cisco Employee,
IDS 3.1 contains IDM & IEV. IDM (IDS Device Manager) is the embedded, browser-based, device manager that provides secure (SSL) management capability. IEV (IDS Device Viewer) allows the user to view alarms from a maximum of 3 sensors. IDS 3.1 is available at $0 for the 4235 and is positioned for the low tier deployments.
Moving upto higher scale deployments, the user may use CSPM which is currently packaged with VMS 2.0 (CWVMS-2.0-WINR-K9 ).
-Mun
