Warning message
edadios Mon, 07/01/2002 - 19:07
  • Silver, 250 points or more
There is really no manual for logs, if that is what you are looking for.
The logs that would show depends on what debug is enabled, and what logging level. Then the show command would display the specified debug to show.
You can try the pic command reference from here, select d for debug, s for show , and l for logging, and it would explaing the command options.
http://www.cisco.com/warp/customer/110/pix_command_ref.shtml .
rsnider Tue, 07/02/2002 - 08:46
If you want an explannation of the different System Log Messages, go to http://cisco.com/ and search on "System log messages version" were version is the release number of your PIX IOS.
Ron
