what does in Frame-relay 0x6450 or 0x4C10 mean ?
Jul 2nd, 2002
  • Bronze, 100 points or more
wg1r5#sh fram map
Serial0.2 (up): point-to-point dlci, dlci 405(0x195,0x6450), broadcast
status defined, active
Serial0.1 (up): point-to-point dlci, dlci 305(0x131,0x4C10), broadcast
Anonymous (not verified) Tue, 07/02/2002 - 11:17
In a frame-relay header, the DLCI is made up of the high order 6 bits of the first octet and the first 4 high order bits of the second octet. With a DLCI of 305, this gives 0x131 as the total 10 bits of address space. The 0x4C10 is the status IE received in the full status response from the frame-relay switch for this DLCI indicating it is active.
