Warning message
IPSec error Director->Sensor
Jul 2nd, 2002
All,
I have a problem that I need some help with. We had a sensor configured,
using IPSec. Someone then changed the org id on the sensor without
removing the IPSec config on the director. I think they also turned off IPSec,
because now I get a lot of errors on my console about non-secure traffic
coming from that source, I can't add the sensor back in the director, and there
is nothing about that host when I check the secure communications info
from sysconfig-director.
So... I thought I might have luck deleting any remnants from the director
using the ipsectool, but I get a warning about the NETRANGER variable being
unset when I try to dump the SA info... HELP!!!!
Georgia Coalman Sat, 07/06/2002 - 16:09
Could you copy and paste the error messages that you're getting to start off with?
basicitone Wed, 08/14/2002 - 06:24
Just had a similar problem. after a org id change we had to readd sensor to director then redo IPSec keys on sensor and director.
