Warning message
CatOs 7.1 and RSTP
Jul 2nd, 2002
Hi all!
We are thinking of using CatOs 7.1 and Rapid Spanning Tree Protocol in a new Backbone. Is there any known issues? Maybe experiences of this solution in a live (not a lab) network?
Petri
bsivasub Tue, 07/02/2002 - 20:35
first of all we support 802.1s with 802.1w if that is what you mean.
Typically you should have just MSTP switches. PVST+ will inter-operate with the MSTP but there are some specific configuration restrictions.
we don't support RSTP alone per vlan currently.
I suggest 7.2.2 software
here is some nice links which is a MUST read
http://www.cisco.com/warp/public/473/#SpanningTree
pkirjala Tue, 07/02/2002 - 20:50
Yes, I meant 802.1s with 802.1w.
In the transition phase we will need to have RSTP working along with the old STP topology. The 7.2.2 software, is it rather new?!
I've read those documents you refer to and I would like to hear experiences from the users.
Thanks anyway!
Petri
milan.kulik Tue, 07/02/2002 - 23:43
  • Red, 2250 points or more
I didn't dare to install RSTP (or MST in Cisco terminology) in my backbone for three reasons:
1) it's too fresh and I'm afraid of bugs
2) if you're running it along with PVST+ switches (and you have to because Cat3500 don't support MST, e.g.) you must move the root bridge into the MST cloud - it's impossible to leave the current network as it is and just add new MST switches
3) from the PVST+ switches point of view the whole MST cloud looks like one "big bridge" which can make STP troubleshooting pretty complicated.
Generally I would try it in a case of building a new network but not in my living productive network which has to be up and running 99,999% of the time.
Milan
pkirjala Wed, 07/03/2002 - 00:50
Hi!
Your reasons number 2 and 3 make the transition phase look rather challenging, I dare say...
Petri
milan.kulik Wed, 07/03/2002 - 01:17
Well,
if you accept this challenge, please let me know your experiences.
Milan
