Are Network Modules hot swappable on the Cat 6509?
Jul 3rd, 2002
  • Bronze, 100 points or more
I have Cat 6509s running and want to insert some new modules. However, I have been unable to find a definitive answer as to whether the insertion of new modules will result in other interfaces on the switch taking a hit when I install the new modules. The documentation I've seen tends to indicate that it won't cause a hit but any advice/experiences are welcome.
Anonymous (not verified) Wed, 07/03/2002 - 13:46
All system elements including power supplies, fans, supervisors, and line-card modules are hot swappable on Catalyst 6500.But i recommend you be more careful with voice modules.
