Warning message
Anonymous (not verified) Wed, 07/03/2002 - 13:46
It is recommended to hard code the frame-relay
addresses using the frame-relay map statement. However,
inverse-arp can typically be used with no problems. Keep
in mind that they do not change dynamically, once
the entries have been established, they remain in the
router unless it is reloaded. If there is a DLCI or IP address
change, it is a good idea to clear this table by using the
clear frame-relay inarp command.
