2600 cannot start up & cannot start from rommon
Jul 3rd, 2002
when I start up 2600, It's start Message just as appendix. Then It has no response.
I try to start it from Rommon. I have used deferent PC with deferent Standard Break Key Sequence Combinations. But It has no response to any Break Signal.
What's wrong with it?
APPENDIX:
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 4K memory for cache initialization
Clearing bss
Reading monitor variables from NVRAM
Enabling interrupts
Enabling instruction cache
Reading cookie
Initializing main memory
Sizing NVRAM
Initializing PCI subsystem
Exiting init
C2600 platform with 32768 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x463e98
Stack pointer : 0x02000000
monstack : 0x8000613C
monra : 0x00000000
edata : 0x8000BEA4
magic : 0xFEEDFACE
memsize : 0x02000000
uncomp_size : 0x00B57250
comp_size : 0x0045FFE0
comp_checksum : 0xE2370D1A
uncomp_checksum : 0x030D113A
Self decompressing the image : ################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################ [OK]
Source elf_hdr->e_shnum = 0x0000000A
Setting up to copy ELF section 0x00000001
to image_info section 0x00000000
sh_name = 0x0000001B
sh_type = 0x00000001
sh_flags = 0x00000006
sh_addr = 0x80008000
sh_offset = 0x00000060
sh_size = 0x0085DF64
sh_link = 0x00000000
sh_info = 0x00000000
sh_addralign = 0x00000020
sh_entsize = 0x00000000
Setting up to copy ELF section 0x00000002
to image_info section 0x00000001
sh_name = 0x00000021
sh_flags = 0x00000002
sh_addr = 0x80865F64
sh_offset = 0x0085DFC4
sh_size = 0x002DA1C3
sh_addralign = 0x00000008
Setting up to copy ELF section 0x00000003
to image_info section 0x00000002
sh_name = 0x00000029
sh_addr = 0x80B40127
sh_offset = 0x00B38187
sh_size = 0x00000001
sh_addralign = 0x00000004
Setting up to copy ELF section 0x00000004
to image_info section 0x00000003
sh_name = 0x00000031
sh_flags = 0x00000003
sh_addr = 0x80B40128
sh_offset = 0x00B38188
sh_size = 0x0001EED8
Setting up to copy ELF section 0x00000005
to image_info section 0x00000004
sh_name = 0x00000037
sh_addr = 0x80B5F000
sh_offset = 0x00B57060
sh_size = 0x00000010
sh_entsize = 0x00000004
cpu type : 0x0000002B
image_info.entry_point = 0x80008000
image_info.section_count = 0x00000005
image_info.monstack = 0x8000613C
image_info.monra = 0x00000000
image_info.param0 = 0x00000002
image_info.param1 = 0x00000000
image_info.param2 = 0x00000000
image_info.param3 = 0x00000000
Section Index = 0x00000000
source = 0x80034490
dest = 0x80008000
bytes = 0x0085DF64
Section Index = 0x00000001
source = 0x808923F4
dest = 0x80865F64
bytes = 0x002DA1C3
Section Index = 0x00000002
source = 0x80B6C5B7
dest = 0x80B40127
bytes = 0x00000001
Section Index = 0x00000003
source = 0x80B6C5B8
dest = 0x80B40128
bytes = 0x0001EED8
Section Index = 0x00000004
source = 0x80B8B490
dest = 0x80B5F000
bytes = 0x00000010
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2600 Software (C2600-I-M), Version 12.1(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Tue 16-May-00 15:15 by ccai
Image text-base: 0x80008088, data-base: 0x80865F64
cisco 2610 (MPC860) processor (revision 0x203) with 28672K/4096K bytes of memory.
Processor board ID JAD05071EAP (75069049)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
bsivasub Thu, 07/04/2002 - 07:24
Does the same console work on any other devices ?
seems that no packets go up the console connection..neither break nor any sequence. I would check the cabling/consoleport issues.
You should use the following URL for break key
http://www.cisco.com/warp/public/701/61.html
