Warning message
PIX- shell authorization and accounting
I've configured my PIX to makea telnet authentication with a TACACS ACS server, now I' ve configured this to take a per user authorization for the exec commands and works fine but :
when the ACS goes down nobody can type a command, the PIX says "authorization failed"?
is there a method to specify a local authorization when the ACS is unreacheble?
Are there some commands to accounting the commands typed by the users?
Thanks VM
Graz.
yusuff Sat, 07/06/2002 - 01:37
  • Cisco Employee,
There is no fallback, so if TACACS goes down, no LOCAL.
There is no actual command accounting available, but by having syslog activated on the PIX, it will show who did what, as shown in the following example:
307002: Permitted Telnet login session from 172.18.124.111
111006: Console Login from pixtest at console
611103: User logged out: Uname: pixtest
502103: User priv level changed: Uname: pixtest From: 1 To: 15
111008: User 'pixtest' executed the 'enable' command.
111007: Begin configuration: 172.18.124.111 reading from terminal
111008: User 'pixtest' executed the 'configure t' command.
111008: User 'pixtest' executed the 'write t' command.
R/Yusuf
