Warning message
DHCP and Default routes
Jul 5th, 2002
I have a 2610 with a 4E connected to a cable modem. I successfully have it connected using DHCP to acquire an IP number. I had to put a static route pointing to the default gateway that the cable compny supplies as pointing to the interface showed just 0.0.0.0. I have to reapply the static route after the lease times out and then it is happy. I can see the lease infor includes
Temp default-gateway addr: 65.29.164.1
So is there a command I am missing to get the router to accept the default gateway as gateway of last resort? I am running Version 12.2(8)T4. I am hoping to use this as my gateway for my home terst network. Thanks in advance for any help.
bpierson Mon, 07/08/2002 - 18:55
I have tried that configuration but then I can't get out. The only config that works is pointing at the default gateway from the lease . I see "Gateway of last resort is 0.0.0.0 to network 0.0.0.0" otherwise. How does the gateway info get pointed at the ethernet interface? I have this under show ip interface brief,"Ethernet1/3 AAA.BBB.CCC.DDD YES DHCP up up" I took out the real IP number but it is there.
