Warning message
Sticky Connections on LD-416
Jul 5th, 2002
Hi:
I have a LocalDirector 416 running Version 4.2.3
I am trying to setup a sticky connection using cookie-passive mode without any luck. First off, I don't understand from looking at the documentation, what the final parameter is used for when configuring for cookie-passive mode (I used "mycookie" as a test value for this parameter). Here is my scenario:
2 IIS web servers (my real servers) being balanced by a single virtual server. I am using cookie-passive mode so that the LD will use the ASPSESSIONID cookie generated by IIS on a request to a stateful .asp application. Subsequent requests by the client are NOT being sent back to the same server, even though the cookie is definitely being sent as a header in the request. For some reason though, cookie-insert mode works as expected. This is why I'm assuming it has to do with that last parameter.
Please help!
Craig Barbisan
Intrigue Technologies
[email protected]
