Warning message
How do you configure the ports on an IP phone?
Jul 8th, 2002
  • Bronze, 100 points or more
On the IP phone, there are two ports, (port 1 and port2) which can be set. Can these be configured or set other than setting ports on the switch? Are these your PC port / LAN switch port as well and can one be shut down or disabled and have the phone not have issues with functionality?
Anonymous (not verified) Mon, 07/08/2002 - 14:24
You can disable the PC port (the one marked (10/100 PC) from within Call Manager. Simply go to the phone's management page and at the bottem is a drop box for PC Port.
I'm not aware of a way to hard code speed/duplex. The LAN port obviously can't be disabled and will auto sense to however you set the upstream switch.
