Warning message
What is this port 2001 used for on the routers??
Jul 8th, 2002
  • Bronze, 100 points or more
A security information officer is doing port scans on our network. Various models of routers keep showing port 2001 open. I need an explanation of what this port is used for and its use for potential security hacks.
Anonymous (not verified) Mon, 07/08/2002 - 14:24
There are TCP ports available for reverse
telnet connectios to physical lines on
a NAS (usually); so port 2001 would be
for line 1 of the NAS.
You can disable this entirely with the
line command .
Or, you can use AAA:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/...
The ports that are potentially usable are here:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1916.htm#xtoci...
