Warning message
difference between bearer cap 0x88902148463B and 0x8890214846BB
Jul 8th, 2002
  • Bronze, 100 points or more
Hi does anybody know the difference between bearer capatiliy 0x88902148463B and 0x8890214846BB
(I know that 0x889021 should be V110)
Background: Hver Problems that v110 Callback is not running and the only difference I can see to the sample on CCO is the bearer cap.
In the sample log
bearer cap and lowlayer Compat
are 0x8890214846BB
in my case
bearer cap is 0x88902148463B
lowlayer Compat 0x8890214846BB
and in my case i get a disconnect
with Cause i = 0x82E4 - Invalid information element contents
Anonymous (not verified) Mon, 07/08/2002 - 14:25
0x88902148463B is a Circuit Mode 64 Kbps
Asynchronous V.110 call with a user
rate of 9.6 kbps. 0x8890214846BB is
the same. In looking at Q931, it looks
like the high order bit should always
be 1 (ie 0xBB instead of 0x3B). You
may want to open a case with the TAC for
this issue, after you have verified that
you see the problem with recent code.
