Warning message
Blocks on SNMP (Port 161) stop printing
Jul 9th, 2002
Applying an ACL to one of the VLANs on a 5513 has disabled all printing between this VLAN to others. The ACL is configured only to block port 161 SNMP, and allow everything else. Hence, the lines are as follows:
access-list 111 deny udp any any eq snmp log
access-list 111 permit ip any any
access-list 111 permit tcp any any
access-list 111 permit udp any any
access-list 111 permit icmp any any
This ACL is applied to a VLAN interface:
For instance:
#conf t
(conf)# int vlan 154
(conf-if)#ip access-group 111 in
Can anyone tell me why this would disable the printing between the workstations on this VLAN?
Thanks so much
umarzoli Wed, 07/10/2002 - 03:01
yes, that is strange. Do you use multilayer switching? If yes, it could be a problem
with the MLS communication between the route processor and the switch or it is just
a bug.
regards Ulrich Marzoli
ww.netaid.de
