Warning message
The necessary VPN sub-system is not available....and more...
Jul 10th, 2002
I receive the above error when attempting to run the VPN dialer on a Windows NT 4.0 system. I have uninstalled and re-installed. However it will not run and I have noticed that my Cisco Systems VPN Service will not run. I get the following message in my Event Viewer
"The Cisco Systems IPsec Driver service depends on the following nonexistent service: NdisWedgeMac"
Any help would be greatly appreciated.
Thank You
Brian
edadios Wed, 07/10/2002 - 17:49
  • Silver, 250 points or more
The best way to resove this if possible would be to rebuild your tcp/ip configuration on the pc. Uninstall the current installed client.
Try and download the latest driver for the NIC, remove the currnet network driver, remove tcp/ip, Reinstall the NIC with the new driver, reinstall tcp/ip, then reinstall the service pack, make sure ip connectivity works , and then reinstall the client.
