Using Policy routing to force WAN frame to go through Watchguard Firewall
Ok.. Here's my situation, I have 45 some odd branch locations all coming in through Frame Relay. As of right now, they have full access to the Internet because they come in one Serial interface of my 2620 router and out the other to the Internet. Only the HQ is protected by the firewall. I want to use Policy routing to force the packets through the firewall so they can be not only protected but monitored as well... Here's a chunk of my config:
interface Serial0/1.XX point-to-point
ip address 10.XX.XX.XX 255.255.255.252 <- 10.0.0.0 scheme for router
no ip directed-broadcast
ip nat inside
frame-relay interface-dlci XXX
ip nat pool XXX XXX.XXX.XXX.X XXX.XXX.XXX.X netmask 255.255.255.224
ip nat inside source list 1 pool XXX overload
access-list 101 permit ip any any
route-map XXX permit 10
match ip address 101
set ip next-hop XXX.XXX.X.XX <- My Firewall (inside address)
route-map XXX permit 20
Help! I have never used policy routing before!
