Warning message
static netbios cache entry
Jul 12th, 2002
Hello
I have two routers connected over dlsw, each router is connected to a
token ring. If i want to configure a static cache entry, which command sould
i use netbios name-cache ...........
or
dlsw icanreach netbios-name ...........
Thanks for your help
Louis
sbales Mon, 07/15/2002 - 12:42
NetBios Name-Caching is an older feature which was used in conjunction with RSRB
and Local Acknowledgement. The cache that DLSw+ keeps for NetBios names is a
completely different cache, optimized for DLSw+ operation. By configuring 'dlsw
icanreach netbios-name ...' on a router, it advertises to its peers via capabilities exchange
that it has a route to the NetBios station in question, thereby creating static remote entries
in each of its remote-peers. This is the configuration you will most likely want to use.
