Warning message
Filtering InterLATA calls based on NPX
Jul 15th, 2002
I'm curious how other people are filtering calls based on NPX. I'm running into an issue lately with InterLATA calls and trying to use a route filter to filter calls to different route lists that point to different PRI's in different LATA's.
The issue I keep running into is that I can only add around 6 different clauses in a route filter. Is there an easier way to do this?
Tim
Tim Medley, CCNP+Voice, CCDP, CWNA
Sr. Network Architect
VoIP Group
iReadyWorld
ciscomoderator Sun, 07/21/2002 - 20:29
  • Gold, 750 points or more
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
