Warning message
ip phone call to bri via SRST gw
Jul 17th, 2002
My BRI is working if srst gateway has connection to CCM. But if it has none, then i am not able to place call via bri interface located on SRST enabled gateway to PSTN. If i look at debug isdn q931, there i do not see called number item. There is no number, therefore it will not connect me.
My srst gw ios is 12.2.8T5. When i change bri interface with FXS interface, everything is working. Does anybody know why my srst gw does not forward dialed digit via bri interface to PSTN?
Martin
Markus Schneider Mon, 07/22/2002 - 06:26
  • Cisco Employee,
What does the pots dial-peer configuration look like of the peer that it is using? You may want to try using the 'forward-digits' command to explicitly send digits to the PSTN. Does this only happen when SRS is active, or is this when everything is fine?
