Warning message
C6K Native IOS: show vlan command
Jul 19th, 2002
Dear NetPro Team,
I would like to know how and where to issue the to me extremly interesting command show vlan internal usage.
Thanks in advance
By the way the command is described in the documentation!
donewald Fri, 07/19/2002 - 08:55
  • Silver, 250 points or more
See this URL:
http://www.cisco.com/univercd/cc/td/doc/product/core/cis7600/12111bex/cmdref/show1.htm#35715
Use the show vlan internal usage command to display internal VLAN allocation information.
Usage Guidelines
If your system is configured with a Supervisor Engine 1, valid values for vlan-id are from 1 to 1005. If your system is configured with a Supervisor Engine 2, valid
values for vlan-id are from 1 to 4094. Extended-range VLANs are not supported on systems configured with a Supervisor Engine 1.
Examples
This example shows how to display current internal VLAN allocation information:
Router# show vlan internal usage
VLAN Usage
1025 -
1026 -
1027 -
1028 -
1029 Port-channel6
1030 GigabitEthernet1/2
1032 FastEthernet3/20
1033 FastEthernet3/21
1129 -
This example shows how to display internal VLAN allocation information for a specific VLAN:
Router# show vlan id 1030 internal usage
VLAN Usage
Hope this helps,
Don
alaquiante Fri, 08/09/2002 - 05:44
Hi Don,
I tried it -after organizing a sup2 and an EX image- and it is working as advertised, thanks a lot!
Have a great weekend
Andy
tstevens Fri, 07/19/2002 - 09:44
  • Cisco Employee,
Internal VLANs are used for:
- a few internal processes, such as diagnostics & multicast, which allocate hidden vlans
- routed interfaces (ie, ports configured as L3 interfaces, not switchports)
- communication between WAN interfaces (OSM, FlexWAN) and PFC/MSFC
So you may want to use this to figure out what vlan IDs have been allocated for the above purposes.
