Warning message
ISDN Dialup error: PPP: Missed 5 keepalives, taking LCP down
Jul 22nd, 2002
This error only occurs on certain ISDN TA's. The multilink comes up but then times out after 90 seconds. None of the timer settings make a difference.
Following is the debug output.
cpta1#sho debug
Dial on demand:
Dial on demand events debugging is on
Dial on demand packets debugging is on
PPP:
PPP authentication debugging is on
PPP protocol negotiation debugging is on
Multilink events debugging is on
ISDN:
ISDN events debugging is on
ISDN Q931 packets debugging is on
ISDN events debug DSLs. (On/Off/No DSL:1/0/-)
DSL 0 --> 31
1 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
ISDN Q931 packets debug DSLs. (On/Off/No DSL:1/0/-)
DSL 0 --> 31
cpta1#term mon
cpta1#
*Mar 1 17:14:30.470: ISDN Se0/0:15: RX <- SETUP pd = 8 callref = 0x0BA8
*Mar 1 17:14:30.470: Bearer Capability i = 0x8890
*Mar 1 17:14:30.470: Channel ID i = 0xA9838D
*Mar 1 17:14:30.474: Called Party Number i = 0x81, '035300', Unknown/ISDN
*Mar 1 17:14:30.474: Sending Complete
*Mar 1 17:14:30.474: ISDN Se0/0:15: Incoming call id = 0xE8, dsl 0
*Mar 1 17:14:30.474: ISDN Se0/0:15: received CALL_INCOMING call_id 0xE8
*Mar 1 17:14:30.474: ISDN Se0/0:15: CALL_INCOMING: call type is DATA, bchan = 12
*Mar 1 17:14:30.474: ISDN Se0/0:15: Event: Received a DATA call from <unknown> on B13 at 64 Kb/s
*Mar 1 17:14:30.474: ISDN Se0/0:15: RM returned call_type 0 resource type 0
*Mar 1 17:14:30.478: ISDN Se0/0:15: TX -> CALL_PROC pd = 8 callref = 0x8BA8
*Mar 1 17:14:30.478: Channel ID i = 0xA9838D
*Mar 1 17:14:30.478: ISDN Se0/0:15: isdn_send_connect(): msg 74, call id 0xE8, ces 1 bchan 12, call type DATA
*Mar 1 17:14:30.558: %LINK-3-UPDOWN: Interface Serial0/0:12, changed state to up
*Mar 1 17:14:30.566: ISDN Se0/0:15: TX -> CONNECT pd = 8 callref = 0x8BA8
*Mar 1 17:14:30.566: Channel ID i = 0xA9838D
*Mar 1 17:14:30.594: ISDN Se0/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x0BA8
*Mar 1 17:14:30.594: ISDN Se0/0:15: received CALL_PROGRESSing call_id 0xE8
*Mar 1 17:14:30.594: ISDN Se0/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0xE8, bchan -1, dsl 0
*Mar 1 17:14:31.338: Se0/0:12 PPP: Treating connection as a callin
*Mar 1 17:14:31.338: Se0/0:12 PPP: Phase is ESTABLISHING, Passive Open
*Mar 1 17:14:31.338: Se0/0:12 LCP: State is Listen
*Mar 1 17:14:31.338: Se0/0:12 LCP: I CONFREQ [Listen] id 1 len 21
*Mar 1 17:14:31.338: Se0/0:12 LCP: MRRU 1600 (0x11040640)
*Mar 1 17:14:31.338: Se0/0:12 LCP: EndpointDisc 5 0216591300 (0x130D0530323136353931333030)
*Mar 1 17:14:31.338: Se0/0:12 LCP: O CONFREQ [Listen] id 3 len 26
*Mar 1 17:14:31.342: Se0/0:12 LCP: AuthProto PAP (0x0304C023)
*Mar 1 17:14:31.342: Se0/0:12 LCP: MagicNumber 0x04F580CD (0x050604F580CD)
*Mar 1 17:14:31.342: Se0/0:12 LCP: MRRU 1524 (0x110405F4)
*Mar 1 17:14:31.342: Se0/0:12 LCP: EndpointDisc 1 Local (0x1308016370746131)
*Mar 1 17:14:31.342: Se0/0:12 LCP: O CONFACK [Listen] id 1 len 21
*Mar 1 17:14:31.342: Se0/0:12 LCP: MRRU 1600 (0x11040640)
*Mar 1 17:14:31.342: Se0/0:12 LCP: EndpointDisc 5 0216591300 (0x130D0530323136353931333030)
*Mar 1 17:14:31.366: Se0/0:12 LCP: I CONFREJ [ACKsent] id 3 len 10
*Mar 1 17:14:31.366: Se0/0:12 LCP: MagicNumber 0x04F580CD (0x050604F580CD)
*Mar 1 17:14:31.366: Se0/0:12 LCP: O CONFREQ [ACKsent] id 4 len 20
*Mar 1 17:14:31.366: Se0/0:12 LCP: AuthProto PAP (0x0304C023)
*Mar 1 17:14:31.370: Se0/0:12 LCP: MRRU 1524 (0x110405F4)
*Mar 1 17:14:31.370: Se0/0:12 LCP: EndpointDisc 1 Local (0x1308016370746131)
*Mar 1 17:14:31.414: Se0/0:12 LCP: I CONFACK [ACKsent] id 4 len 20
*Mar 1 17:14:31.414: Se0/0:12 LCP: AuthProto PAP (0x0304C023)
*Mar 1 17:14:31.414: Se0/0:12 LCP: MRRU 1524 (0x110405F4)
*Mar 1 17:14:31.414: Se0/0:12 LCP: EndpointDisc 1 Local (0x1308016370746131)
*Mar 1 17:14:31.414: Se0/0:12 LCP: State is Open
*Mar 1 17:14:31.414: Se0/0:12 PPP: Phase is AUTHENTICATING, by this end
*Mar 1 17:14:31.430: Se0/0:12 PAP: I AUTH-REQ id 34 len 13 from "isdn"
*Mar 1 17:14:31.430: Se0/0:12 PAP: Authenticating peer isdn
*Mar 1 17:14:31.430: Se0/0:12 PAP: O AUTH-ACK id 34 len 5
*Mar 1 17:14:31.430: %DIALER-6-BIND: Interface Se0/0:12 bound to profile Di20
*Mar 1 17:14:31.430: Se0/0:12 MLP: Multilink up event pending
*Mar 1 17:14:31.434: Se0/0:12 PPP: Phase is VIRTUALIZED
*Mar 1 17:14:31.434: Di20 DDR: Authenticated host isdn with no matching dialer map
*Mar 1 17:14:31.434: Di20 PPP: Phase is UP
*Mar 1 17:14:31.434: Di20 IPCP: O CONFREQ [Closed] id 5 len 10
*Mar 1 17:14:31.434: Di20 IPCP: Address AA.AA.AA.AA (0x0306143E6C0A)
*Mar 1 17:14:31.438: Se0/0:12 MLP: isdn, multilink up, first link
*Mar 1 17:14:31.494: Di20 CCP: I CONFREQ [Not negotiated] id 4 len 10
*Mar 1 17:14:31.494: Di20 CCP: MS-PPC supported bits 0x00000001 (0x120600000001)
*Mar 1 17:14:31.494: Di20 LCP: O PROTREJ [Open] id 5 len 16 protocol CCP (0x80FD0104000A120600000001)
*Mar 1 17:14:31.506: Di20 IPCP: I CONFREQ [REQsent] id 5 len 40
*Mar 1 17:14:31.506: Di20 IPCP: CompressType VJ 15 slots CompressSlotID (0x0206002D0F01)
*Mar 1 17:14:31.506: Di20 IPCP: Address 0.0.0.0 (0x030600000000)
*Mar 1 17:14:31.506: Di20 IPCP: PrimaryDNS 0.0.0.0 (0x810600000000)
*Mar 1 17:14:31.506: Di20 IPCP: PrimaryWINS 0.0.0.0 (0x820600000000)
*Mar 1 17:14:31.506: Di20 IPCP: SecondaryDNS 0.0.0.0 (0x830600000000)
*Mar 1 17:14:31.506: Di20 IPCP: SecondaryWINS 0.0.0.0 (0x840600000000)
*Mar 1 17:14:31.506: Di20 IPCP: Pool returned ZZ.ZZ.ZZ.ZZ
*Mar 1 17:14:31.506: Di20 IPCP: O CONFREJ [REQsent] id 5 len 22
*Mar 1 17:14:31.510: Di20 IPCP: I CONFACK [REQsent] id 5 len 10
*Mar 1 17:14:31.510: Di20 IPCP: Address AA.AA.AA.AA (0x0306143E6C0A)
*Mar 1 17:14:31.538: Di20 IPCP: I CONFREQ [ACKrcvd] id 6 len 22
*Mar 1 17:14:31.538: Di20 IPCP: Address 0.0.0.0 (0x030600000000)
*Mar 1 17:14:31.538: Di20 IPCP: PrimaryDNS 0.0.0.0 (0x810600000000)
*Mar 1 17:14:31.538: Di20 IPCP: SecondaryDNS 0.0.0.0 (0x830600000000)
*Mar 1 17:14:31.538: Di20 IPCP: O CONFNAK [ACKrcvd] id 6 len 22
*Mar 1 17:14:31.542: Di20 IPCP: Address ZZ.ZZ.ZZ.ZZ (0x0306143E6D3C)
*Mar 1 17:14:31.542: Di20 IPCP: PrimaryDNS BB.BB.BB.BB (0x8106143203F9)
*Mar 1 17:14:31.542: Di20 IPCP: SecondaryDNS CC.CC.CC.CC (0x8306143E0F04)
*Mar 1 17:14:31.570: Di20 IPCP: I CONFREQ [ACKrcvd] id 7 len 22
*Mar 1 17:14:31.570: Di20 IPCP: Address ZZ.ZZ.ZZ.ZZ (0x0306143E6D3C)
*Mar 1 17:14:31.570: Di20 IPCP: PrimaryDNS BB.BB.BB.BB (0x8106143203F9)
*Mar 1 17:14:31.570: Di20 IPCP: SecondaryDNS CC.CC.CC.CC (0x8306143E0F04)
*Mar 1 17:14:31.574: Di20 IPCP: O CONFACK [ACKrcvd] id 7 len 22
*Mar 1 17:14:31.574: Di20 IPCP: Address ZZ.ZZ.ZZ.ZZ (0x0306143E6D3C)
*Mar 1 17:14:31.574: Di20 IPCP: PrimaryDNS BB.BB.BB.BB (0x8106143203F9)
*Mar 1 17:14:31.574: Di20 IPCP: SecondaryDNS CC.CC.CC.CC (0x8306143E0F04)
*Mar 1 17:14:31.574: Di20 IPCP: State is Open
*Mar 1 17:14:31.574: Di20 DDR: dialer protocol up
*Mar 1 17:14:31.578: Di20 IPCP: Install route to ZZ.ZZ.ZZ.ZZ
*Mar 1 17:14:32.406: ISDN Se0/0:15: RX <- SETUP pd = 8 callref = 0x0CA8
*Mar 1 17:14:32.406: Bearer Capability i = 0x8890
*Mar 1 17:14:32.406: Channel ID i = 0xA9838C
*Mar 1 17:14:32.406: Called Party Number i = 0x81, '035300', Unknown/ISDN
*Mar 1 17:14:32.406: Sending Complete
*Mar 1 17:14:32.406: ISDN Se0/0:15: Incoming call id = 0xE9, dsl 0
*Mar 1 17:14:32.410: ISDN Se0/0:15: received CALL_INCOMING call_id 0xE9
*Mar 1 17:14:32.410: ISDN Se0/0:15: CALL_INCOMING: call type is DATA, bchan = 11
*Mar 1 17:14:32.410: ISDN Se0/0:15: Event: Received a DATA call from <unknown> on B12 at 64 Kb/s
*Mar 1 17:14:32.410: ISDN Se0/0:15: RM returned call_type 0 resource type 0
*Mar 1 17:14:32.410: ISDN Se0/0:15: TX -> CALL_PROC pd = 8 callref = 0x8CA8
*Mar 1 17:14:32.410: Channel ID i = 0xA9838C
*Mar 1 17:14:32.414: ISDN Se0/0:15: isdn_send_connect(): msg 74, call id 0xE9, ces 1 bchan 11, call type DATA
*Mar 1 17:14:32.490: %LINK-3-UPDOWN: Interface Serial0/0:11, changed state to up
*Mar 1 17:14:32.498: %ISDN-6-CONNECT: Interface Serial0/0:12 is now connected to <unknown phone number> isdn
*Mar 1 17:14:32.498: ISDN Se0/0:15: TX -> CONNECT pd = 8 callref = 0x8CA8
*Mar 1 17:14:32.502: Channel ID i = 0xA9838C
*Mar 1 17:14:32.514: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:12, changed state to up
*Mar 1 17:14:32.526: ISDN Se0/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x0CA8
*Mar 1 17:14:32.530: ISDN Se0/0:15: received CALL_PROGRESSing call_id 0xE9
*Mar 1 17:14:32.530: ISDN Se0/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0xE9, bchan -1, dsl 0
*Mar 1 17:14:33.250: Se0/0:11 PPP: Treating connection as a callin
*Mar 1 17:14:33.250: Se0/0:11 PPP: Phase is ESTABLISHING, Passive Open
*Mar 1 17:14:33.254: Se0/0:11 LCP: State is Listen
*Mar 1 17:14:33.254: Se0/0:11 LCP: I CONFREQ [Listen] id 1 len 21
*Mar 1 17:14:33.254: Se0/0:11 LCP: MRRU 1600 (0x11040640)
*Mar 1 17:14:33.254: Se0/0:11 LCP: EndpointDisc 5 0216591300 (0x130D0530323136353931333030)
*Mar 1 17:14:33.254: Se0/0:11 LCP: O CONFREQ [Listen] id 3 len 26
*Mar 1 17:14:33.254: Se0/0:11 LCP: AuthProto PAP (0x0304C023)
*Mar 1 17:14:33.254: Se0/0:11 LCP: MagicNumber 0x04F5884C (0x050604F5884C)
*Mar 1 17:14:33.254: Se0/0:11 LCP: MRRU 1524 (0x110405F4)
*Mar 1 17:14:33.254: Se0/0:11 LCP: EndpointDisc 1 Local (0x1308016370746131)
*Mar 1 17:14:33.254: Se0/0:11 LCP: O CONFACK [Listen] id 1 len 21
*Mar 1 17:14:33.258: Se0/0:11 LCP: EndpointDisc 5 0216591300 (0x130D0530323136353931333030)
*Mar 1 17:14:33.286: Se0/0:11 LCP: I CONFREJ [ACKsent] id 3 len 10
*Mar 1 17:14:33.286: Se0/0:11 LCP: MagicNumber 0x04F5884C (0x050604F5884C)
*Mar 1 17:14:33.286: Se0/0:11 LCP: O CONFREQ [ACKsent] id 4 len 20
*Mar 1 17:14:33.286: Se0/0:11 LCP: AuthProto PAP (0x0304C023)
*Mar 1 17:14:33.286: Se0/0:11 LCP: MRRU 1524 (0x110405F4)
*Mar 1 17:14:33.286: Se0/0:11 LCP: EndpointDisc 1 Local (0x1308016370746131)
*Mar 1 17:14:33.318: Se0/0:11 LCP: I CONFACK [ACKsent] id 4 len 20
*Mar 1 17:14:33.318: Se0/0:11 LCP: AuthProto PAP (0x0304C023)
*Mar 1 17:14:33.318: Se0/0:11 LCP: MRRU 1524 (0x110405F4)
*Mar 1 17:14:33.318: Se0/0:11 LCP: EndpointDisc 1 Local (0x1308016370746131)
*Mar 1 17:14:33.322: Se0/0:11 LCP: State is Open
*Mar 1 17:14:33.322: Se0/0:11 PPP: Phase is AUTHENTICATING, by this end
*Mar 1 17:14:33.322: Se0/0:11 PAP: I AUTH-REQ id 2 len 13 from "isdn"
*Mar 1 17:14:33.326: Se0/0:11 PAP: Authenticating peer isdn
*Mar 1 17:14:33.326: Se0/0:11 PAP: O AUTH-ACK id 2 len 5
*Mar 1 17:14:33.326: %DIALER-6-BIND: Interface Se0/0:11 bound to profile Di20
*Mar 1 17:14:33.326: Se0/0:11 MLP: Multilink up event pending
*Mar 1 17:14:33.326: Se0/0:11 PPP: Phase is VIRTUALIZED
*Mar 1 17:14:33.330: Se0/0:11 MLP: isdn, multilink up
*Mar 1 17:14:34.326: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:11, changed state to up
*Mar 1 17:14:38.498: %ISDN-6-CONNECT: Interface Serial0/0:11 is now connected to <unknown phone number> isdn
*Mar 1 17:14:45.826: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 44 bytes, outgoing interesting (list 100)
*Mar 1 17:14:45.870: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 52 bytes, outgoing interesting (list 100)
*Mar 1 17:14:45.874: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 600 bytes, outgoing interesting (list 100)
*Mar 1 17:14:45.878: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 220 bytes, outgoing interesting (list 100)
*Mar 1 17:14:46.010: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 46 bytes, outgoing interesting (list 100)
*Mar 1 17:14:46.270: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:47.486: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:47.726: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:47.966: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:48.206: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:48.446: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:48.782: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:49.022: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:49.066: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 50 bytes, outgoing interesting (list 100)
*Mar 1 17:14:50.054: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:50.214: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:50.514: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 42 bytes, outgoing interesting (list 100)
*Mar 1 17:14:50.522: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 50 bytes, outgoing interesting (list 100)
*Mar 1 17:14:51.870: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:52.110: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:52.350: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:52.590: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:52.890: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:53.210: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:53.450: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 40 bytes, outgoing interesting (list 100)
*Mar 1 17:14:53.522: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 48 bytes, outgoing interesting (list 100)
*Mar 1 17:14:54.382: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:54.582: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:54.862: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:55.102: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:55.382: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:55.546: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:56.502: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:57.102: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 43 bytes, outgoing interesting (list 100)
*Mar 1 17:14:57.494: ISDN Se0/0:15: RX <- SETUP pd = 8 callref = 0x0DA8
*Mar 1 17:14:57.494: Bearer Capability i = 0x9090A3
*Mar 1 17:14:57.494: Channel ID i = 0xA9838B
*Mar 1 17:14:57.494: Progress Ind i = 0x8483 - Origination address is non-ISDN
*Mar 1 17:14:57.494: Called Party Number i = 0x81, '035300', Unknown/ISDN
*Mar 1 17:14:57.494: Sending Complete
*Mar 1 17:14:57.498: ISDN Se0/0:15: Incoming call id = 0xEA, dsl 0
*Mar 1 17:14:57.498: ISDN Se0/0:15: received CALL_INCOMING call_id 0xEA
*Mar 1 17:14:57.498: ISDN Se0/0:15: CALL_INCOMING: call type is VOICE, bchan = 10
*Mar 1 17:14:57.498: ISDN Se0/0:15: Event: Received a VOICE call from <unknown> on B11 at 64 Kb/s
*Mar 1 17:14:57.534: ISDN Se0/0:15: TX -> CALL_PROC pd = 8 callref = 0x8DA8
*Mar 1 17:14:57.534: Channel ID i = 0xA9838B
*Mar 1 17:14:57.534: ISDN Se0/0:15: TX -> ALERTING pd = 8 callref = 0x8DA8
*Mar 1 17:14:57.538: ISDN Se0/0:15: VOICE_ANS Event: call id 0xEA, bchan 10, ces 1
*Mar 1 17:14:57.538: ISDN Se0/0:15: isdn_send_connect(): msg 74, call id 0xEA, ces 0 bchan 10, call type VOICE
*Mar 1 17:14:57.538: ISDN Se0/0:15: TX -> CONNECT pd = 8 callref = 0x8DA8
*Mar 1 17:14:57.582: ISDN Se0/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x0DA8
*Mar 1 17:14:57.582: ISDN Se0/0:15: received CALL_PROGRESSing call_id 0xEA
*Mar 1 17:14:57.582: ISDN Se0/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0xEA, bchan -1, dsl 0
*Mar 1 17:14:57.782: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:57.982: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:58.222: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:58.462: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:58.714: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:14:58.926: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 66 bytes, outgoing interesting (list 100)
*Mar 1 17:14:59.278: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 42 bytes, outgoing interesting (list 100)
*Mar 1 17:14:59.290: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 282 bytes, outgoing interesting (list 100)
*Mar 1 17:15:01.790: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:01.950: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:02.234: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:02.474: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:02.594: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:02.754: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:02.958: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:03.290: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 42 bytes, outgoing interesting (list 100)
*Mar 1 17:15:03.306: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 67 bytes, outgoing interesting (list 100)
*Mar 1 17:15:03.682: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 600 bytes, outgoing interesting (list 100)
*Mar 1 17:15:03.682: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 211 bytes, outgoing interesting (list 100)
*Mar 1 17:15:04.406: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 592 bytes, outgoing interesting (list 100)
*Mar 1 17:15:06.682: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 572 bytes, outgoing interesting (list 100)
*Mar 1 17:15:08.278: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 600 bytes, outgoing interesting (list 100)
*Mar 1 17:15:08.278: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 91 bytes, outgoing interesting (list 100)
*Mar 1 17:15:08.878: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 600 bytes, outgoing interesting (list 100)
*Mar 1 17:15:08.878: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 114 bytes, outgoing interesting (list 100)
*Mar 1 17:15:09.954: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 600 bytes, outgoing interesting (list 100)
*Mar 1 17:15:09.958: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 471 bytes, outgoing interesting (list 100)
*Mar 1 17:15:11.394: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 600 bytes, outgoing interesting (list 100)
*Mar 1 17:15:11.394: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 410 bytes, outgoing interesting (list 100)
*Mar 1 17:15:11.990: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 600 bytes, outgoing interesting (list 100)
*Mar 1 17:15:11.994: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 434 bytes, outgoing interesting (list 100)
*Mar 1 17:15:12.630: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 600 bytes, outgoing interesting (list 100)
*Mar 1 17:15:12.630: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 236 bytes, outgoing interesting (list 100)
*Mar 1 17:15:13.270: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 197 bytes, outgoing interesting (list 100)
*Mar 1 17:15:25.934: Se0/0:12 PPP: Missed 5 keepalives, taking LCP down
*Mar 1 17:15:25.934: Se0/0:12 MLP: Multilink down event pending
*Mar 1 17:15:25.934: Se0/0:12 PPP: Phase is DOWN
*Mar 1 17:15:25.934: Se0/0:15 DDR: has total 30 call(s), dial_out 0, dial_in 1
*Mar 1 17:15:25.934: Se0/0:12 PPP: Treating connection as a callin
*Mar 1 17:15:25.934: Se0/0:12 PPP: Phase is ESTABLISHING, Passive Open
*Mar 1 17:15:25.934: Se0/0:12 LCP: State is Listen
*Mar 1 17:15:25.938: %DIALER-6-UNBIND: Interface Se0/0:12 unbound from profile Di20
*Mar 1 17:15:25.938: Se0/0:12 DDR: disconnecting call
*Mar 1 17:15:25.938: ISDN Se0/0:15: Event: Hangup call to call id 0xE8
*Mar 1 17:15:25.938: ISDN Se0/0:15: process_disconnect(): call id 0xE8, call type is DATA, b_idb 0x61FB73F0, ces 1, cause 0x10
*Mar 1 17:15:25.938: %ISDN-6-CONNECT: Interface Serial0/0:11 is now connected to <unknown phone number> isdn
*Mar 1 17:15:25.942: %ISDN-6-DISCONNECT: Interface Serial0/0:12 disconnected from <unknown phone number> isdn, call lasted 55 seco
nds
*Mar 1 17:15:25.942: ISDN Se0/0:15: TX -> DISCONNECT pd = 8 callref = 0x8BA8
*Mar 1 17:15:25.942: Cause i = 0x8090 - Normal call clearing
*Mar 1 17:15:25.946: Se0/0:12 MLP: Removing link from isdn
*Mar 1 17:15:25.982: ISDN Se0/0:15: RX <- RELEASE pd = 8 callref = 0x0BA8
*Mar 1 17:15:25.982: ISDN Se0/0:15: TX -> RELEASE_COMP pd = 8 callref = 0x8BA8
*Mar 1 17:15:25.982: ISDN Se0/0:15: CCPRI_ReleaseCall(): bchan 13, call id 0xE8, call type DATA
*Mar 1 17:15:25.986: ISDN Se0/0:15: received CALL_CLEARED call_id 0xE8
*Mar 1 17:15:26.026: %LINK-3-UPDOWN: Interface Serial0/0:12, changed state to down
*Mar 1 17:15:26.034: Se0/0:12 LCP: State is Closed
*Mar 1 17:15:26.034: Se0/0:12 PPP: Phase is DOWN
*Mar 1 17:15:26.034: Se0/0:12 DDR: disconnecting call
*Mar 1 17:15:26.934: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:12, changed state to down
*Mar 1 17:15:33.062: isdn MLP: Lost fragment 1a 6F
*Mar 1 17:15:36.602: isdn MLP: Lost fragment 1a 71
*Mar 1 17:15:37.158: isdn MLP: Lost fragment 1a 73
*Mar 1 17:15:37.162: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:37.322: isdn MLP: Lost fragment 1a 75
*Mar 1 17:15:37.322: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:37.642: isdn MLP: Lost fragment 1a 77
*Mar 1 17:15:37.642: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:37.882: isdn MLP: Lost fragment 1a 79
*Mar 1 17:15:37.882: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:38.090: isdn MLP: Lost fragment 1a 7B
*Mar 1 17:15:38.590: isdn MLP: Lost fragment 1a 7D
*Mar 1 17:15:38.594: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:38.682: isdn MLP: Lost fragment 1a 7F
*Mar 1 17:15:38.686: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:39.294: isdn MLP: Lost fragment 1a 81
*Mar 1 17:15:39.294: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 41 bytes, outgoing interesting (list 100)
*Mar 1 17:15:40.603: isdn MLP: Lost fragment 1a 83
*Mar 1 17:15:40.607: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 42 bytes, outgoing interesting (list 100)
*Mar 1 17:15:40.615: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 266 bytes, outgoing interesting (list 100)
*Mar 1 17:15:40.859: isdn MLP: Lost fragment 1a 85
*Mar 1 17:15:41.579: isdn MLP: Lost fragment 1a 87
*Mar 1 17:15:43.955: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 268 bytes, outgoing interesting (set by protocol)
*Mar 1 17:15:44.043: isdn MLP: Lost fragment 1a 89
*Mar 1 17:15:44.903: isdn MLP: Lost fragment 1a 8B
*Mar 1 17:15:44.903: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 49 bytes, outgoing interesting (list 100)
*Mar 1 17:15:46.103: isdn MLP: Lost fragment 1a 8D
*Mar 1 17:15:46.107: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 52 bytes, outgoing interesting (list 100)
*Mar 1 17:15:47.703: isdn MLP: Lost fragment 1a 8F
*Mar 1 17:15:47.703: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 42 bytes, outgoing interesting (list 100)
*Mar 1 17:15:47.719: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 67 bytes, outgoing interesting (list 100)
*Mar 1 17:15:48.091: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 600 bytes, outgoing interesting (list 100)
*Mar 1 17:15:48.091: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 211 bytes, outgoing interesting (list 100)
*Mar 1 17:15:48.271: isdn MLP: Lost fragment 1a 91
*Mar 1 17:15:49.911: isdn MLP: Lost fragment 1a 93
*Mar 1 17:15:49.915: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 592 bytes, outgoing interesting (list 100)
*Mar 1 17:15:51.171: isdn MLP: Lost fragment 1a 95
*Mar 1 17:15:51.175: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 572 bytes, outgoing interesting (list 100)
*Mar 1 17:15:55.679: isdn MLP: Lost fragment 1a 97
*Mar 1 17:15:55.683: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 600 bytes, outgoing interesting (list 100)
*Mar 1 17:15:55.687: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 91 bytes, outgoing interesting (list 100)
*Mar 1 17:16:02.551: ISDN Se0/0:15: RX <- SETUP pd = 8 callref = 0x0EA8
*Mar 1 17:16:02.551: Bearer Capability i = 0x8890
*Mar 1 17:16:02.551: Channel ID i = 0xA9838A
*Mar 1 17:16:02.551: Called Party Number i = 0x81, '035300', Unknown/ISDN
*Mar 1 17:16:02.551: Sending Complete
*Mar 1 17:16:02.555: ISDN Se0/0:15: Incoming call id = 0xEB, dsl 0
*Mar 1 17:16:02.555: ISDN Se0/0:15: received CALL_INCOMING call_id 0xEB
*Mar 1 17:16:02.555: ISDN Se0/0:15: CALL_INCOMING: call type is DATA, bchan = 9
*Mar 1 17:16:02.555: ISDN Se0/0:15: Event: Received a DATA call from <unknown> on B10 at 64 Kb/s
*Mar 1 17:16:02.555: ISDN Se0/0:15: RM returned call_type 0 resource type 0
*Mar 1 17:16:02.559: ISDN Se0/0:15: TX -> CALL_PROC pd = 8 callref = 0x8EA8
*Mar 1 17:16:02.559: Channel ID i = 0xA9838A
*Mar 1 17:16:02.559: ISDN Se0/0:15: isdn_send_connect(): msg 74, call id 0xEB, ces 1 bchan 9, call type DATA
*Mar 1 17:16:02.635: %LINK-3-UPDOWN: Interface Serial0/0:9, changed state to up
*Mar 1 17:16:02.647: ISDN Se0/0:15: TX -> CONNECT pd = 8 callref = 0x8EA8
*Mar 1 17:16:02.647: Channel ID i = 0xA9838A
*Mar 1 17:16:02.671: ISDN Se0/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x0EA8
*Mar 1 17:16:02.675: ISDN Se0/0:15: received CALL_PROGRESSing call_id 0xEB
*Mar 1 17:16:02.675: ISDN Se0/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0xEB, bchan -1, dsl 0
*Mar 1 17:16:08.567: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 600 bytes, outgoing interesting (set by protocol)
*Mar 1 17:16:08.643: %ISDN-6-CONNECT: Interface Serial0/0:9 is now connected to unknown
*Mar 1 17:16:12.643: Se0/0:9 DDR: disconnecting call
*Mar 1 17:16:12.643: ISDN Se0/0:15: Event: Hangup call to call id 0xEB
*Mar 1 17:16:12.643: ISDN Se0/0:15: process_disconnect(): call id 0xEB, call type is DATA, b_idb 0x61FA1BB0, ces 1, cause 0x10
*Mar 1 17:16:12.643: %ISDN-6-DISCONNECT: Interface Serial0/0:9 disconnected from unknown , call lasted 10 seconds
*Mar 1 17:16:12.647: ISDN Se0/0:15: TX -> DISCONNECT pd = 8 callref = 0x8EA8
*Mar 1 17:16:12.647: Cause i = 0x8090 - Normal call clearing
*Mar 1 17:16:12.683: ISDN Se0/0:15: RX <- RELEASE pd = 8 callref = 0x0EA8
*Mar 1 17:16:12.687: ISDN Se0/0:15: TX -> RELEASE_COMP pd = 8 callref = 0x8EA8
*Mar 1 17:16:12.687: ISDN Se0/0:15: CCPRI_ReleaseCall(): bchan 10, call id 0xEB, call type DATA
*Mar 1 17:16:12.687: ISDN Se0/0:15: received CALL_CLEARED call_id 0xEB
*Mar 1 17:16:12.731: %LINK-3-UPDOWN: Interface Serial0/0:9, changed state to down
*Mar 1 17:16:12.739: Se0/0:9 LCP: State is Closed
*Mar 1 17:16:12.739: Se0/0:9 DDR: disconnecting call
*Mar 1 17:16:34.335: Di20 DDR: ip (s=AA.AA.AA.AA, d=ZZ.ZZ.ZZ.ZZ), 600 bytes, outgoing interesting (set by protocol)
*Mar 1 17:16:51.987: ISDN Se0/0:15: RX <- DISCONNECT pd = 8 callref = 0x0CA8
*Mar 1 17:16:51.991: Cause i = 0x819F - Normal, unspecified or Special intercept, call blocked group restriction
*Mar 1 17:16:51.991: ISDN Se0/0:15: received CALL_DISC call_id 0xE9
*Mar 1 17:16:51.995: %ISDN-6-DISCONNECT: Interface Serial0/0:11 disconnected from <unknown phone number> isdn, call lasted 139 sec
onds
*Mar 1 17:16:52.039: %LINK-3-UPDOWN: Interface Serial0/0:11, changed state to down
*Mar 1 17:16:52.043: Se0/0:15 DDR: has total 30 call(s), dial_out 0, dial_in 0
*Mar 1 17:16:52.043: Se0/0:11 MLP: Multilink down event pending
*Mar 1 17:16:52.043: Se0/0:11 PPP: Phase is TERMINATING
*Mar 1 17:16:52.043: Se0/0:11 LCP: State is Closed
*Mar 1 17:16:52.043: Se0/0:11 PPP: Phase is DOWN
*Mar 1 17:16:52.043: Se0/0:11 DDR: disconnecting call
*Mar 1 17:16:52.043: %DIALER-6-UNBIND: Interface Se0/0:11 unbound from profile Di20
*Mar 1 17:16:52.047: ISDN Se0/0:15: TX -> RELEASE pd = 8 callref = 0x8CA8
*Mar 1 17:16:52.067: Se0/0:11 MLP: Removing link from isdn
*Mar 1 17:16:52.067: isdn MLP: Removing bundle
*Mar 1 17:16:52.067: Di20 IPCP: State is Closed
*Mar 1 17:16:52.067: Di20 PPP: Phase is TERMINATING
*Mar 1 17:16:52.071: Di20 IPCP: Remove route to ZZ.ZZ.ZZ.ZZ
*Mar 1 17:16:52.071: ISDN Se0/0:15: RX <- RELEASE_COMP pd = 8 callref = 0x0CA8
*Mar 1 17:16:52.075: ISDN Se0/0:15: CCPRI_ReleaseCall(): bchan 12, call id 0xE9, call type DATA
*Mar 1 17:16:52.075: ISDN Se0/0:15: received CALL_CLEARED call_id 0xE9
*Mar 1 17:16:53.035: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:11, changed state to downundebug all
All possible debugging has been turned off
The config: (serial is channelized E1)
isdn switch-type primary-net5 (PRI)
isdn voice-call-failure 0
interface Serial0/0:15
no ip address
no ip directed-broadcast
encapsulation ppp
dialer pool-member 1
dialer pool-member 2
dialer pool-member 3
autodetect encapsulation ppp v120
isdn incoming-voice modem 56
isdn guard-timer 3000
fair-queue 64 256 0
no cdp enable
ppp authentication pap chap ms-chap callin
ppp multilink
interface Dialer20
ip unnumbered FastEthernet0/0
encapsulation ppp
keepalive 3600
dialer remote-name isdn
dialer pool 2
dialer idle-timeout 3600
dialer-group 1
peer default ip address pool dialin_pool
no cdp enable
ppp authentication chap
ppp multilink
ppp timeout multilink link remove 180
dialer-list 1 protocol ip list 100
access-list 100 permit ip any any
Any ideas?
Petri.
mljohnson Mon, 07/22/2002 - 14:24
I can't explain why it's different with different TA's, but I would suggest you configure the keepalive timer on the physical interface instead of the dialer. You might also ensure that you have fairly recent code; I don't see a cisco bug that matches what you are seeing, but newer code may help (in addition to the config change). Note that, in general, a keepalive of 3600 is almost worthless. This means that 5 hours will go by before we signal a problem with the link, should there be any. The keepalive packet is small and insignificant, and so (in general) you should stick with the 10 second default and then when you see the message "Missed 5 keepalives, taking LCP down" you should then verify that the line is clear of errors or drops.
