Warning message
VPN setup for Single building site
Jul 22nd, 2002
Can anyone point me towards samples or white papers regarding the setup of a VPN for a wireless LAN at a single building site? The WLAN is all set up on the same vlan using Cisco Aironet 340 access points. The access points are connected to various Cisco switches spread out across 4 floors and then enter the WAN via a Cisco 6509. While I can find several examples regarding multiple sites and remote access, I can not find any examples of a single site using the VPN for security purposes. I am required to set up a VPN. No other options are permissable.
awaheed Mon, 07/22/2002 - 16:36
  • Cisco Employee,
I just wanted to mention a link which has alot of SAFE Whitepapers and in the List you will find the one with Wireless and VPN design discussion aswell. the link is : http://www.cisco.com/offer/tdm_home/vpn/learn.shtml and it should be 4-5 on the list.
Hope this helps,
Aamir Waheed,
Cisco Systems, Inc.
CCIE#8933
