Warning message
digit translation
Jul 25th, 2002
we have a DID Range of 2400-2499. our internal extensions are 54XX.
i want to configure the h.323 gateway to ring 5422 when 2422 DID comes in the gateway without having 2422 showup as an extension on the phone.
I was hoping that this could be done with no call manager involvement . so basically i want the gateway to translate 2422 into 5422 and then send the call manager to ring the appropriate phone.
m.hedberg Thu, 07/25/2002 - 04:22
yes i figured it out
num-exp 2422 5422
thanks for the quick reply
hkanters Thu, 07/25/2002 - 04:47
i think "num-exp 2422 5422" is not the best solution
better use : num-exp 24xx 54xx
or num-exp 24.. 54..
(do not know what wildcard is xx or .. )
m.hedberg Thu, 07/25/2002 - 05:23
for me it is because it is only for a few phones that i want to do this for but your right this is not a scalable method
