interesting traffic not bring up backup link using DDR and dialer profile.
Jul 25th, 2002
Thanks for showing an interest!
Here's the situation, We have a remote site with a frame relay connection (via ser0) which we want to back up with an isdn backup line using ddr and a dialer profile to the main site.
Here is the config of the router
:version 12.0
service timestamps debug datetime
service timestamps log datetime
service udp-small-servers
service tcp-small-servers
hostname remoterouter
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication ppp default local
aaa authorization exec default group tacacs+
aaa accounting exec default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
enable secret 5 xxxxxxxxxxxx
enable password xxxxxxxxxxxxx
username master password 7 xxxxxxxxxxxxxxx
username trr004x password 7 xxxxxxxxxxxxx
clock timezone gmt 0
clock summer-time bst recurring last Sun Mar 2:00 last Sun Oct 2:00
ip subnet-zero
isdn switch-type basic-net3
isdn voice-call-failure 0
isdn tei-negotiation first-call
interface Loopback0
no ip address
no ip directed-broadcast
interface Ethernet0
ip address 10.28.0.1 255.255.252.0
ip helper-address 10.2.44.200
ip helper-address 10.2.16.10
keepalive 4
interface Serial0
description Frame-Relay Link
bandwidth 64
ip address 10.1.16.2 255.255.252.0
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
no fair-queue
frame-relay map ip 10.1.16.1 100 broadcast
frame-relay lmi-type ansi
interface Serial1
no ip address
shutdown
interface BRI0
description dial backup link
bandwidth 56
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
no keepalive
dialer pool-member 1
no fair-queue
no cdp enable
interface Dialer0
ip address 10.2.176.10 255.255.255.0
encapsulation ppp
dialer remote-name trr004x
dialer pool 1
dialer idle-timeout 90
dialer string 01793848012
dialer-group 1
no fair-queue
no cdp enable
ppp authentication chap
ppp multilink
interface Dialer1
no ip address
no cdp enable
router eigrp 1
network 10.0.0.0
network 144.98.0.0
no auto-summary
no ip classless
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip route 0.0.0.0 0.0.0.0 Dialer0 200
no ip http server
logging trap debugging
access-list 101 deny eigrp any any
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
tacacs-server host 10.2.44.208
tacacs-server host 10.2.44.206
tacacs-server timeout 1000
tacacs-server key cisco
snmp-server engineID local 00000009020000E01E3E7080
snmp-server community public xxxxxxx
line con 0
transport input none
line aux 0
password xxxxxxxx
no activation-character
modem InOut
stopbits 1
flowcontrol hardware
line vty 0 4
password xxxxxxx
ntp clock-period 17179522
ntp server 144.98.31.172
end
MRR001X#sh ver
IOS (tm) 2500 Software (C2500-P-L), Version 12.0(7)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Mon 06-Dec-99 19:39 by phanguye
Image text-base: 0x0303C3D4, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOF)
MRR001X uptime is 22 hours, 16 minutes
System restarted at 15:17:01 bst Wed Jul 24 2002
System image file is "flash:c2500-p-l.120-7.T.bin"
cisco 2500 (68030) processor (revision N) with 6144K/2048K bytes of memory.
Processor board ID 06099777, with hardware revision 00000001
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
One problem is that the dialer interface is not dialing out when I ping an ip address on the main site from the remote site after having shut down the frame relay serial interface (administritively). I have tried pinging directly from the remote router and the dialer interface is not dialing out. The bri interface is working as it brings itself up to connect to the ntp server every couple of minutes (which is another problem).
The floating static default route is shown in the route table after having shut down the serial interface along with the subnets of the ethernet and dialer interfaces (and all the eigrp routes disappear).
If i do a debug dialer packets i see the following:
Jul 25 10:30:56: Dialer0 DDR: ip (s=10.2.176.10, d=224.0.0.10), 60 bytes, outgoing uninteresting (list 101)
Jul 25 10:31:00: Dialer0 DDR: ip (s=10.2.176.10, d=224.0.0.10), 60 bytes, outgoing uninteresting (list 101)
but no sign of the ping attempts that are running on the network. I would have expected to see the pings in the debug as interesting traffic but there is no sign of them.
Please let me know if you need any further information.
Rgds,
Martin
vcjones Thu, 07/25/2002 - 13:24
  • Silver, 250 points or more
Look up the meaning of "no ip classless" and consider if that is really what you want... (remember that 10.*.*.* are all in the same major network). That should take care of your pings.
As for NTP bringing up the line, look at your definition of "interesting traffic" in access-list 101. Last time I checked, NTP used IP. You need to add a deny line for UDP packets using the NTP port.
Good luck and good hunting!
Vincent C Jones
