Warning message
Disabling call pickup on an ISDN interface
Jul 25th, 2002
I have a mc3810 with a bri card. I have the router configured to use the bri port for dial-backup, but I want to configure the router so it will not pick up incoming isdn calls. I just want the call to ring as if nothing was there. Is this possible?
tepatel Thu, 07/25/2002 - 08:54
  • Cisco Employee,
Router will accept the incoming call..Now there are way to reject the call after it comes to router, using dialer profile..(based in CallerID). But for that you need to have callerID enabled for incoming calls...
But best way is Talk to BRI provider and have them disable the incoming call capability on that bri line..Tejal
