Warning message
Cisco Pix 515 multiple site vpn with the same private ip address
Jul 31st, 2002
Is there any document available that deals extensively with the multiple sites vpn with the same private ip address and all the sites have Cisco Pix firewall.
Thanks in Advance
paqiu Wed, 07/31/2002 - 04:29
Here is URL for PIX to VPN 3000 VPN tunnel with overlaping private network.
http://www.cisco.com/warp/customer/707/vpn_pix_private.html
If you have several PIX, you just copy the PIX config and change it should be fine. The idea is NAT translate the overlapping network to something else. After that, build up the VPN tunnel for both translated networks.
Best Regards,
