VoiceGateway and PBX CAS signal
Aug 1st, 2002
Hi to all,
is it possible to connect a PBX to a gateway through a CAS channel as follow:
PBX1 ---cas---- gw ------ IP ------- gw -------cas ----- PBX2
having a call from channel 20 of PBX1 going to channel 20 of PBX2 ?
If yes, which kind of gateway (2600,3600,as5300) and voice-card are needed?
Chris
mimckee Thu, 08/01/2002 - 10:31
  • Cisco Employee,
I don't see why this would not be possible. You can user any of the router platforms you have mentioned. Depending on the platform you will also need a voice card for the interface to the T1.
Thank you,
-Mckee
