Warning message
redistribution igrp/ospf
dsalisbury Thu, 08/01/2002 - 12:22
IGRP only knows classful routes (A, B, or C). When you redistribute OSPF into IGRP all routes will become classful. Unless all you networks are class C's you may have problems.
vkhanduri Mon, 08/05/2002 - 10:35
I have not seen your config, to me it looks like the routes that you are missing are those routes which traverse a network which is definitely not summarized or is in a different mask as from your IGRP link. Or may be you are trying to summarize Area 0 route which is not possible other than null ing it .
I bet you, if you do show ip route on the IGRP ONLY (Remote) router, the network, which all the missing routes should pass, is also not in the table.
Vikas
vkhanduri Mon, 08/05/2002 - 10:38
And as far as network possbilby down message goes, it looks like your you have a serial interface on the remote router which is not using sub interface , hence you need to disable split horizon for what ever protocol you are using.
Vikas
