Warning message
Gatekeeper 'no' commands???
Aug 2nd, 2002
Anyone know how to remove zone commands?
I've found using the 'no' command does not work as in a router. The 'no' command seems to mean reverse the intention of the associated command, and doesn't remove the command from the config.
If I want to remove the following command, 'no' does not remove the command;
zone subnet extgk.xyz.com 10.1.0.0/32 enable
I end up with;
no zone subnet extgk.xyz.com 10.1.0.0/32 enable
Which is not what I want, I want to just remove the command.
Any ideas??
thomas.chen Fri, 08/09/2002 - 14:03
  • Silver, 250 points or more
Try utilizing "disable" rather than "enable" in the zone subnet command.
paolo Thu, 12/05/2002 - 16:18
Make sure you are in gatekeeper configuration
GK01>ena
Password:
GK01#conf t
Enter configuration commands, one per line. End with CNTL/Z.
GK01(config)#gate
GK01(config-gk)#
ctrieu Fri, 12/06/2002 - 15:19
  • Cisco Employee,
Please remove the local zone in the gatekeeper and put it back.
This will remove the no zone subnet from the configuration.
For example:
2611-2#s run | beg gatek
gatekeeper
zone local gk5 cisco5.com
no zone subnet gk5 101.1.1.1/32 enable
gw-type-prefix 9* gw ipaddr 172.16.13.163 1720
no shutdown
2611-2#conf t
2611-2(config)#gatek
2611-2(config-gk)#shut
2611-2(config-gk)#no zone local gk5 cisco5.com
2611-2(config-gk)#end
2d04h: %SYS-5-CONFIG_I: Configured from console by console
gatekeeper
shutdown
2611-2#conf t
2611-2(config-gk)#no shut
WARNING: There are no local zones configured. The gatekeeper will
remain in an inactive state until local zone(s) are defined.
2611-2(config-gk)# zone local gk5 cisco5.com
gatekeeper
no shutdown
Chinh
